XY Graph cursor Error
Hello
This error was found, when I started using LabView 8, with my old LabView 6.1 VI's.
I have encountered a minor error on my Graph display. I noticed my Y-Scale numbers go negative, if I Press and Hold my Graph cursor, while I am moving it.
I run this same test using New LV 8 XY Graph and numbers do not go negative, but they surely flicker a lot + numbers still change some.
Have you noticed this before? Is there some new property I need to set up, to make my LabView 6.1 Graph stable? Is this known bug or am I just doing something wrong?
Here is VI for your testing. My LabView 8 version is 8.0.0.4005.
Just run it and while moving yellow cursor (press+hold+move), after 1-2 seconds of holding something happens.
Yours
                                     Kari
(2,684 Views)
Hello Karik.
I experience the exact same problem in the application I'm programming. The only solution I have come up with is having the cursors Y-axis centered in the visible area of the graph.
However this is really bad because there is will create a smal "hole" in the cursor bar, it looks awfull. I think this is a bug in lv8 since in lv7.1 I could tie down the y-axis to like -10000 or something and the problem would not appear.
Hope NI fixes this problem really really soon.
//Andreas
(2,639 Views)
