XY Graph: Visible Data Only
Is there a way to directly retrieve only the currently visible data (within X and Y scale limits) from an XY graph, perhaps from a property node? I couldn't find any documentation on XY graph's properties from NI.
Alternatively, what's the best way to conditionally index an array in LabView? I can only think of inelegant ways to accomplish array conditional array indexing in Labview, but surely there must be a good way to do this.
In python I would do:
    y_visible = y[(x > 3) & (x < 9)]
where the X axes limits are 3 and 9. This line gets the subarray of y where x is between 3 and 9.
Thanks!
(3,453 Views)
By default the upper limit is exclusive, but you can right click the "in range and coerce" function to change that.
(3,442 Views)
Same for the Y values. Use an AND inside the loop to match both conditions.
(3,419 Views)
This is more efficient, and compatible with older versions of LV
(3,380 Views)
You can use property node to retrieve the X and Y limits and get the data from that limits.  Create a XY graph property node Select X-Axis ---> Range--> Minimum \ Maximum. Use the same for Y-Axis.
CLD Using LabVIEW since 2013
(3,373 Views)
This has nothing to do with an xy graph.
(3,369 Views)
for:
"In python I would do:
is applicable
(3,364 Views)
