XY Graph Endpoint
Hi everbody,
i have a following problem. As is evident from a pictures my last point in the chart is always connected to the first point of my chart.
What could i do to fix that problem ?
thx
Message 1 of 8
(5,117 Views)
Hi grba,
at first: clean up your VI.
Next step: initialize the shift registers with arrays, which are initialized with a default value of NaN (instead of 0)!
Message 2 of 8
(5,101 Views)
It's hard to say exactly since you show so little code, but it looks like you are trying to preinitialize your data arrays but perhaps are not collecting enough data to overwrite all the initialization values. Where is the rest of your code?
Another problem is that you are overusing local variables. I can tell because I see one.
You should also get rid of the express VI. All you need is a cluster bundler.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(5,097 Views)
Hi GerdW,
i'll take care of my code 🙂 . it's perfect. now all working fine. i have tried with Inf, -Ind but never with NaN 😞
Thanks for your tipp
Message 4 of 8
(5,087 Views)
...except it's not perfect, and it's not working fine. If it were you wouldn't have asked for help.
What NaN does is prevent a particular data point from being plotted.
Mike...
LabVIEW Champion
Message 5 of 8
(5,084 Views)
Even without showing your code:   Put a probe at the XY graph input and look at the data (end of the arry) Somehow I'm pretty shure you will find some [0,0] left over...
Perfect code with a local variable 'Step' to size your array??
Hidden wires ??
YMMD 😄    "my code is perfect"          run Tools-> VI Analyser  and learn!
And a RG I like ... convert to dynamic data, use express vi to pass data into a xy graph 🙂      have a look at the help about xy graph and the provides examples
it's easy like this:
Sorry ...   it's friday...
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 8
(5,061 Views)
Hi everyone,
thanks for your help! with your help i woud learn everything what i need.so i am very grateful for every tip or some critique.
I send my code.
I have one question ? can i get the LabView code in C e.g Python ?.. or can i get linear code ? Thx
Message 7 of 8
(5,017 Views)
Hi grba,
When you want C code you should create your programs using a text editor and a C compiler.
When you want Python code you should use the same text editor and a Python compiler…
As long as you use the LabVIEW IDE you get LabVIEW VIs and an executable!
What is "linear code"?
Your code uses way too much local variables…
Message 8 of 8
(4,994 Views)
