XY Graph Cursor Problem in Labview 7.1.1?
Hallo,
I am  using Labview 7.1.1 and I am facing one problem with XY graph cursor. If I am moving cursor in one graph, I am expecting same movement in another Graph. But when I move cursor in Graph1, cursor in second graph moves but not to exact X value of Graph1.
Property of Cursor in both graphs must be "Lock to Plot"
If any body knows about this please let me know ASAP. I am attaching example VI for your reference.
Sashi
(2,540 Views)
It's a curious effect. Probably the floating point coordinate is sensitive to the exact pixel alignment (I mean that this would not happen if we had for example 1 pixel per point in the X direction).
Anyway, if you use Cursor Index instead (which is an integer) the behaviour is as expected.
Paolo
Paolo
(2,535 Views)
