XNET remote connection to PXI
I want to use the XNET-Cards in a PXI realtime system from the (Windows-) Host PC. The application code would run on the Host-PC and XNET data would be sent/received via a TCP/IP connection between Host-PC and realtime system. This is the same configuration that is used by the XNET Busmonitor (port 13456). My question is if the protocol used by the Busmonitor is documented somewhere and if I can use it for my own application. If not, I will have to write my own little server-code running on the realtime system. But before I do that I just wanted to make sure I'm not re-inventing the wheel.
Thanks & Regards
Dirk
(2,677 Views)
Hello Krid,
Unfortunately, the Busmonitor protocol is not documented.
(2,614 Views)
