XNET & CAN - Control when Frame is being TX
We have some code which takes in a CAN DBC, sets up the CANBUS (Termination Set, etc...) as well as the TX rate.
We have another bit of code which generates the 64-bit contents of the message, again at 100hz.
However, we have a problem with that those two 100Hz processes are ever so slightly out of sync sometimes resulting in the occasional skipped message (I.e. you can see that a step has been skipped) or retransmitted message (I.e. contents the same).
Is there a better way to synchronise the TX? Can we take over that with the XNET/CAN block so the message generation loop controls when the frame is TX onto the CANBUS?
Thanks.
(855 Views)
See Hardware Time Based Control of CAN Frame Transmit Time with NI-XNET
https://tmesystems.net/
(791 Views)
