XNET Auto Response to a specific ID
I have read loads of documentation and cannot find what I am looking for. Apologies if it is obvious.
I have a HIL (Hardware in Loop) system which tests an ECU. The ECU sends CAN frames periodically and the sensors are supposed to respond to specific CAN IDs with sensor data as a response.
For example if the ECU sends a Frame (CAN Identifier 1) with signal Temp set to 1, my simulated sensor is supposed to respond with a specific frame with temperature information in the payload. So it needs to be a response to a trigger. I tried many things but not sure how to set XNET driver to do an event response.
Please helps. Thanks in advance.
Peter
CLD
(2,788 Views)
Hi Peter,
I have found the following link which provides some information on how to trigger an Event Remote Frame.
Handling Remote Frames with NI-XNET in LabVIEW
https://forums.ni.com/t5/Example-Code/Handling-Remote-Frames-with-NI-XNET-in-LabVIEW/ta-p/3996140
Please let me know whether this is what you're looking for or if you have any further questions.
Jaimie
(2,733 Views)
