XMODEM
I am looking to implement XMODEM protocol in LabVIEW for serial port communications.
From some browsing on the web it seems like I will need a 3rd party tool?
I was wondering if anyone can recommend any 3rd party tools they have successfully used?
I can across the following, has anyone on the forums used it?
http://www.commstudio.com/commstudio/protocols/xmodem
They have ActiveX components.
Thanks & Regards,
Don1
(4,821 Views)
I've never tried them, but you can try Mark's VIs that he posted on LAVA a few years back: http://lavag.org/topic/11011-xmodem-protocol-using-hyperterminal/
(4,813 Views)
HyperAccess also has an ActiveX interface. I did not use it with LabVIEW but with TestStand.
(4,801 Views)
Thanks for all the suggestions. I will look at both of them.
I am developing the overall test automation in TestStand - if I use HyperAcces I can always do it in TestStand. ould you have a working example in TestStand that you would be able to share with me?
Thanks & Regards,
Don1
(4,794 Views)
See this.
(4,789 Views)
Any one has a XMODEM 1K file Transfer vi, if u have any idea on XMODEM 1K file Transfer please post the replay.
In my Project i want to transfer a 1K XMODEM file transfer through Serial Port.
(4,661 Views)
(4,646 Views)
