XMLHTTPRequest returns code, not data
When calling a VI for data using XMLHTTPRequest, the VI is supposed to run and return the data as the response.  What might be the problem if, instead of returning the response, the server returns the contents of the VI file?
(3,205 Views)
It appears that the VI is being served as static content (which I allow in the target properties, Web Server: Configuration | Allow Access).
The request header is:
Host10.1.13.50
User-AgentMozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.2) Gecko/20100115 Firefox/3.6 (.NET CLR 3.5.30729)
Accepttext/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Languageen-us,en;q=0.5
Accept-Encodinggzip,deflate
Accept-CharsetISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive115
Connectionkeep-alive
X-Requested-WithXMLHttpRequest
Refererhttp://10.1.13.50/user_interface.html
The response header is:
DateWed, 17 Mar 2010 19:45:50 GMT
ServerMbedthis-Appweb/2.3.0
Content-Typetext/plain
Last-ModifiedWed, 17 Mar 2010 19:40:58 GMT
Etag"17e-359b-4ba1304a"
Content-Length13723
Keep-Alivetimeout=60000, max=8
The response is (truncated):
RSRC
LVINLBVW��1������� ��1����x`����� ��������<@������������������������C{J���˧F�n��� ������sL�T��H�2�llg���ُ��� ���B~��@��������0��ُ��� ���B~��?�l�1��4��v�"ѷ�W~|��e�J��g�������LVINXHR_handler.vi�������VIVI�����NI_InternetTK_Core_VIs.lvlibCGI Read Request.vi�PTH0���=���<vilib>addonsinternethttpcgi.llbCGI Read Request.vi������������������������VIVI����NI_InternetTK_Core_VIs.lvlib%CGI Parse URL-Encoded Param String.vi�PTH0���O���<vilib
The size of the response (in bytes) is the same size as the VI file on the target.
(3,200 Views)
More interesting than the request header would be the requested URL.
Rolf Kalbermatter  My Blog
(3,189 Views)
URL:  http://10.1.13.50/user_interface.html.  This loads the js file and the js file requests cgi-bin/XHR_handler.vi.
Target is cRIO-9074.
(3,186 Views)
When you navigate to the website with a browser, are things fine? Or is this just happening when using the LabVIEW function to retreive the XML?
-Zach
(3,142 Views)
