XMLDOM Document to LV string
I've got the attached noddy program to write an XMLDOMDocument to a file. How do I get the output to go to an LV string?
All help greatly appreciated!
(2,612 Views)
Hi sensornet,
I'm not sure if i understand what exactly you are looking for.     The output is already on your block diagram, you could just wire a string indicator to this and then use that as an output.    You could also use the file i/o functions to extract the string from the file.
If I have missed the point please let me know.
thanks
Seamus
(2,596 Views)
