XML file instead of an ini file in CVI
Has anyone used an XML file to retain state information fro a CVI application in lieu of the registry or an .ini file?
Has anyone generated a report using XML?
I normally would use a Word template and paste to bookmarks using ActiveX to make a report, but someone here at work seemed to think that I could or should do this with XML instead.
I see in the Wiki XML entry there's a pull-parser scheme to get data from an XML file using the iterator design pattern - anyone tried this?
Thanks for any insight anyone cares to share.
Menchar
(2,705 Views)
This is the LabVIEW forum.
You need to post your question in the LabWindows/CVI forum.
(2,699 Views)
Sorry about that, chief.
(2,695 Views)
