XML Parsing with JKI EasyXML - XML to Array
I got some problems with parsing xml strings to Labview.
Im using JKI EasyXML. But i got problems to convert the XML values to an Array. What am i doing wrong?
Please take a look at the attached Vi.
(4,112 Views)
Accepted by topic author DocHardinger
Have a look at the examples that come with that toolkit. Your XML-string is not in a format that this toolkit will use for an array.
Regards, Jens
Kudos are welcome...
(4,082 Views)
Okay thx...
ALready thought that i first need to change the string to the correct format...or i will just write my own parser... anyway thx for your answer
(4,062 Views)
The toolkit works, just update your cluster typedef to include an 'items' cluster around the 'item' array to work with that XML structure.
(3,634 Views)
