XControl dynamic default value
In any case, bug or not bug, the time delay seems essentially unpredictable. I previously rejected this solution because of its theoretical unreliability. Race conditions are painfull to deal with but are acceptable when they can be controlled and prevented in a deterministic way (i.e.. no randomness, one will be 100% sure it is avoided).
Is there any event/value/trigger... that can be used to change the value of the XControl before it is first used in the Block diagram ? Or should we all conclude that there is no way to make a deterministic XControl-based Tick Count (ms)-like node ?
Best regards
Message 11 of 16
(1,820 Views)
Best regards
Yes, you could do it with the init ability, when the previous version info shows 0.0.0.0 you have a fresh drop.
As I said earlier the following two events should be triggered before the VI finishes loading:
There is a specific event triggered when a VI is loaded into memory (Display State Change) and one when the VI started executing (ExecState Change).
Both of them should update the BD value of the XControl.
Ton
My LabVIEW Ideas
Message 12 of 16
(1,804 Views)
Sorry Ton, your solution eludes me, even after having written more than 1000 VIs myself.
In the attached file in my first post, in the Facade VI, the Data Out is always Tick Count (ms). Yet the "Run when opened.vi" always returns 0.
Also the init ability cannot set the XControl value directly. Can you be more specific on your solution to make a Tick-Count XControl ?
Regards
Message 13 of 16
(1,794 Views)
What happens if you put the MS timer inside the timeout event?
It might be that LabVIEW assumes that the Data In and Data Out are at the same memory position and not looks at the terminals but at the Data In position.
Ton
My LabVIEW Ideas
Message 14 of 16
(1,782 Views)
Placing the Tick Count node inside the timeout event of the XControl facade VI still make the XControl return 0 in the "Run when opened" VI.
I also tried to set the value of XControl through the Refnum of the Container State, assuming some internal other way of setting the XControl value, but the result is again 0.
Regards
Message 15 of 16
(1,768 Views)
Hi Ben,
This was reported to R&D (# 133433) for further investigation.  I do not know whether they will consider it a bug or simply update the documentation, but they have been made aware of the issue. Thanks for the feedback!
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
Message 16 of 16
(1,727 Views)
