XControl Popup Menu
Copy the attached file to C:\ ... \LabVIEW 20xx\resource\plugins\PopupMenus\edit time panel and diagram\
(made with LV 2018.  Mass compile if using a later version).
Then when you right-click on an XControl, you get this:
(1,657 Views)
Right after I submitted that, I thought that I should add another menu item to apply changes and unlock the XControl.  But what to call it?  The first thought is "Apply Changes to Instances"; but that's really not appropriate because its meaningful from the context of the XControl library, but this the the context of an instance.  So things that come to mind are:
  • Update from library and unlock
  • Update instances from library and unlock
But those are terribly wordy.  What do you think?
(1,638 Views)
