X-Y plot with different colours
Dear gredw and everyone,
Thanks. I did the timestamp conversion and splitting up the array into 3 parts.
Now i face the problem how to i get all the array to be plotted into one x-y graph with different colours. Can you advise me? The arrays (1,2,3 ) may be of different elements and sizes.
I have attached the codes. Can anyone guide me on this?
I am also wondering are there any plots that can show different colours based on data level threshold? IS there a much simpler plot (intensity map or others etc) that can do similar application?
Thank you so  much!
Message 11 of 12
(610 Views)
Accepted by topic author Joven
Hi Joven,
as said before: build plots from your sorted data, then create an array of plots:
Two notes:
- don't use local variables when you can use a wire. There are several race conditions in your code! (See those "1", "2", "3" arrays on the left in the image? No more locals of them!)
- you created a lot of duplicated code: you should design your algorithm on a sheet of paper BEFORE you start to code… (See those two loops in the image: they to the very same job! Why not work with arrays and autindexing loops? Or even use subVIs?)
Message 12 of 12
(603 Views)
