X-Axis Real Time
I created a VI file to capture the temperature but the x-axis origin, Xo that I obtained always show start at 8.30 am, how can I made it so that the origin of x-axis is always 1 minutes before the pc's system time
(2,635 Views)
Hmmm... Not sure that I undestand clearly what you want as this looks a liitle bit strange for me that you want to set x-axis origin to be "always 1 minutes before the pc's system time", but... if you want, one of the approaches to change x-axis origin is just to set appropriate graph property (so you need to create a propery node for your graph)...
See example attached - hope this helps
(2,635 Views)
