I have simplified the VI evading calls to other VIs and trying to reproduce the mistake.
The type of string I introduce to reproduce the mistake is:
clock 3 (30) clock (40)
Forgetting to introduce a number between the second "clock" and the following parenthesis, I would manage it programmatically with code that isn't included.
Then "Scan From String" is supposed to do not make a conversion. But it leaves a 2 as output (in this example)
I have realised, unbelievable but true, that it has matter with the number I substract to the output number (if it were 2, I would obtain 1 as output and so on)
Excluding that, I got the conversion made before as output, 3, on the second time that "Scan From String" executes. But, how can this func
tion as bad?
I am using LV4 on an old PC. I have tried to reproduce it with LV6 and it works. But it isn't desirable for me, I would have to convert a lot of VIs and surely I will find a lot of errors due to the conversion (I have already tried)
