Wrong result in match pattern
Hi, I want to extract the space (sometimes, !#" etc) from "@020 12345' using match pattern function.
When I used [\s!#"] as a regular expression, the result "20".
Why my expression is not worked and Can you propose more suitable expression?
labmaster
*)Enclosed is the VI example in LV2009
(2,681 Views)
Accepted by topic author labmaster
Your string indicator is set to hex display. 0x20 is a space, right? 😉
(2,675 Views)
You should also describe what you mean by "extract". If you simply need a space, you can use a space diagram constant. No need to extract it. Do you want the resulting string without the space, for example?
I am sure one of the regex gurus here will jump right on this one... 😉
(2,673 Views)
Wow, I had a mistake to interprete the indicator. Happen to be "20".
Thanks.
labmaster.
(2,655 Views)
