Wrong data from VISA
I reading data from a balance.
The balance is set to auto print which means that I print continually.
My data should look like “ 182.12 g”. The string should start with a space and end with a carriage return.
Unfortunately my data often looks like this “øø^ñ 182,12 g”
The RS232 settling for the balance should be 2400,none,7,1
Message 1 of 15
(4,899 Views)
increase your wait time step by step  untill you get no wired data also attach byte at port to number of byte to read instead of 200
Message 2 of 15
(4,869 Views)
Hello mkoppelgaard,
why are you reading 200 bytes with the function VISA read? I think you don't need to read so much bytes.
Kind regards.
Message 3 of 15
(4,866 Views)
The VISA Bytes at Serial Port should not be needed at all and specifying 200 bytes to read is perfectly fine. Neither of you must have much experience with serial communication.
mkoppelgard,
Do you see the same behavior when you use MAX or a program such as Putty?
Message 4 of 15
(4,849 Views)
Try attached vi... I added a VISA CLEAR after initialisation. I hope the rubbish data disappears that way...
Then I wait for the buffer to be 5> bytes before reading.   “ 182.12 g”   , but it should be 9 if your Visa-input is always 9 bytes... 🙂
Message 5 of 15
(4,842 Views)
When your data ends with a carriage return, then you should use it.  Make sure you enable the termination character in the Serial Configure and that you set it to carriage return (13 or x0D).  By default it is enabled but is linefeed (10 or x0A).  Then you can use a sufficiently large number (200 being just fine) with your VISA Read.  And as Dennis said, you don't need the "Bytes at Port" property.
Message 6 of 15
(4,802 Views)
Thank you Xilinx. NSmiley Very Happy
RavensFan: My data ends with 13 10.  I dont understand this "Make sure you enable the termination character in the Serial Configure and that you set it to carriage return (13 or x0D)" ? Where do I do this settling?
From time to time I recieve the error 1073676294. What can be the reason?
Message 7 of 15
(4,779 Views)
please try this one. I made some corrections on it. I hope, I will work.
Ermaksan Machine R&D
Electronics Engineer
Message 8 of 15
(4,764 Views)
The VISA Configure Serial Port has an input for the termination character. Clearly visible in the Context Help. Right click on the input and select Create Constant.
You don't have an error, it's a warning and caused by the incorrect termination character specified.
Message 9 of 15
(4,752 Views)
Erdalozandilek: The previous version was better. Now I get wrong results again.
Dennis: Since the sting ends with 0D 0A I guess the default settling is okay?? But do the settling course the string to be cut after 0D0A or…?
Message 10 of 15
(4,734 Views)
