Wrong AC Current reading?
It's alright I think, if I just divide by 4, I still can get the correct reading regardless if I change the load.. So I guess probably there is a part of calculation or reading with mistake. Anyway, thanks for your help!
Message 11 of 12
(1,077 Views)
I hope you are not using the results of your measurement for anything which is critical to safety, or which will be published or used as part of a thesis.
Multiplying by an arbitrary "fudge" factor without any more justification than "it gives the answer I want" is not acceptable behavior for most purposes.
You really should find out what is going on.
Lynn
Message 12 of 12
(1,054 Views)
