Writing to spreadsheet with queue
I'm a beginner with queues and I have a few questions.  I've attached a simple example of code I wrote to better implement a consumer that can queue up data and write to a spreadsheet after running the code.
First, I've noticed that the queue always has a residual element remaining after the code ends.  It then writes that element to file upon rerunning the vi.  I can't figure out how to get rid of this element.
Second, does anyone have any suggestions to improve this code?  I've been playing around with it for quite awhile and I finally got it to work like this, but it is definitely set up differently than other examples I've seen.
Third, I am trying to read out the number of elements in the queue, but both in the producer and consumer loop it tells me there are zero elements.  How can this be?  My output file seems to be working and I am certainly putting elements into the queue.
Lastly, in the future I will be using the data from the queue in two places.  Here I have set up a notifier to do the job.  Is this the best method?
Thanks for your help!
Jason
(4,051 Views)
Accepted by topic author Panzonbackwards
The reason you are not getting the last element of the queue (at least not until you restart the VI) is that you have your auto-indexing tunnel that is accumulating all the data to send to the Write to SS File function wired to the shift register.  So that last piece of data from the queue gets put into the shift register, but doesn't get put into the 2-D array by the auto-indexing tunnel until the next iteration of the loop.  When you rerun the VI, because the shift register is uninitialized, it is already there and becomes the first point of your next run of data.
Why did you put the shift register in?  Just eliminate it and just use the auto-indexing tunnel.
I don't know what you really want to do with the 2nd loop to say whether a notifier is correct or not.  But if you don't want to lose data in the other loop, then what you should use is a second queue, and have your producer loop enqueue the data in both queues, one queue for each consumer loop.
As for seeing zero elements in the queue, the way your code is setup, the queue will nearly always be empty because the dequeue function will be ready to pull the element out immediately after the enqueue function puts it in.  Unless you have your producer loop running significantly faster than your consumer loop, you won't see a build up of elements.  (Try putting a wait longer than 100 msec in your consumer loop.  Then you will see elements build up in the queue.)
I'm not sure why you are putting the Write to Spreadsheet File function after the loop.  A normal usage for queues in a producer/consumer architecture is to pass the data to a separate loop that contains the file writing functions.  That way it can operate at its own pace, but write out the data, and make sure you don't lose it.  As you have it now, if your code runs a long time, you could run out of memory when the array at the auto-indexing tunnel gets too large.  And if your application crashes before you end it with your stop button, then all data is lost because you had not written it out to the file.
(4,041 Views)
Thanks for the help.  Actually, on the second loop where I placed the notifier, I would just like to keep as up to date as possible.  It doesn't matter if I drop data in that instance.  It's important that I don't fall behind, so I think a notifier is the best option.  Do you agree?
(4,022 Views)
A notifier should be just fine for you then.
(4,004 Views)
