Writing to registers Watlow F4
I have been struggling with writing to registers to shut off chambers and hold profiles on the Watlow F4. I am using the Labview provided driver and the Read/Write Digital Output function to try and access the registers. Unfortunately I cannot provide you my vi. However, I have received the error - 1074001420 after using this function. Any explanation would be great as I am fairly new to using the Watlow F4.
Thanks!
(873 Views)
Hi k,
This error number is undefined for my LV2019 installation.
So you better debug your VI, which you cannot provide…
(861 Views)
The error is directly sourced to the Watlow F4 driver and only shows up when this specific function is in use. My vi runs perfectly fine when I do not include it. I was wondering if I could receive input on how to write to a register with the Watlow driver since I cannot do so with the Read Write Digital Output function. I can include the function vi if needed.
(830 Views)
