Writing to Measurement File Logging Issue
I'm using the Write to Measurement File vi in a consumer loop in my main vi to log data. The first time I run the main vi after opening it, the data logs properly. However, in subsequent runs, my data is not logged. However, if I close my main vi and reopen it, the data logs properly.
In each run, I log to a differently named data file. I don't specifically close any files, but my assumption is that that is taken care of in the Write to Measurement File vi.
Any idea what might be going on/any potential fixes? I'm in LabVIEW 2014.
(3,519 Views)
The express vi will open and close the file every iteration.   Can you provide your code? Smiley Very Happy
-Matt
(3,510 Views)
No idea.
But if you attach your VI so we can see how you programmed it, then maybe we can help figure it out.
(3,508 Views)
Unfortunately because of company policies I can't, but I was able to solve my problem; it was an issue with my looping stop condition. Thank you for your help!
(3,480 Views)
