Writing thesis using Labview developed software
Good Aftrnoon.
My Masters thesis is based on developed software using Labview.  Can anyone suggest the best way to write up the main sections?
For example, how to go about describing the general experimental flow? My ideas were to use flow-charts, taking  Print Screens of labview code and describing what each of subVIs does. Anyone had experience in that area?  Or if you can share a thesis based on writtten LabView program, it would be ideal for reference. Thank you in advance
Kiryl
(6,408 Views)
I wouldn't do it like you describe. That's what API reference and LabVIEW help are for.
You have a lot to cover before your start with the functions.
Things like the difference between dataflow and imperative programming.
The free parallelization that you get from this.
How commong programing paradigms are represented in labview (flow of control, constants, values)
Design decisions for LabVIEW, and what theirt advantages/disadvantages are.
How inputs and outputs differe from normal languages
SubVIs, modularizarion and code organization
What are the limitations and advantages of VI files.
The problems of "each wire is a copy".
OOP in LabVIEW
The "bad" side of LabVIEW programming.
After you cover all of that and whatever a forgot to mention, I would give a couple of examples, if the thesis still seems incomplete.
Mr, Mike
(6,396 Views)
Thanks Miki,
I will have a look at suggested topics.
(6,391 Views)
Accepted by topic author Kiryl
If your project markers are not familiar with LabVIEW, then frankly they shouldn't be supervising a LabVIEW project.
In the same way you wouldn't be expected to literally print the whole codebase of a project done in a written language, you dont need to go into the same level of detail with a LabVIEW project.
You can document your code with system flow charts, Annotate snippets of interesting bits of code, write pseudo code to illustrate functionality,
_____________________________
- Cheers, Ed
(6,383 Views)
Thanks Ad,
that what I had in mind: to document interesting bits of code and skip all the routine. Pseudo code idea sound very interesting.
I belive submitting a disk with all LabiView VIs along with printed copy should be a solution if anybody gets interested to get deep into reading.
Kiryl
(6,374 Views)
