Writing text with NXT icon
Hi
Using LabView 2010 I tried to write text in certain x,y position and not in line. I could not find an equivalent Icon to do the job, Needed to use the NXT_DisplayText from the remote vi library (see attached picture)
The Vis from the remote library cannot be connected to the new NXT icon vi's  (Why?) and when i tried to link the sequence flow out from such a vi to the new vi i get an error message.
Questions:
how can I use the new NXT Icons to do the job?
was I right to select the remote library vi?
what should i do if i want to control the flow sequence usingboth types of vi's
attached is a description of a program I wrote in which i had this problem
Moshe
23386i79C4C712DC49C634
(3,198 Views)
Hi Moshe,
Can you post both a screen shot of the error you are getting and your VI?
Thanks!
Tanya Visser
LabVIEW Group Manager
(3,160 Views)
Hi Tanya
Thank you for your reply.
Although I posted this call for help, I have continued to search for the solution myself and finally I found that there is a vi to write to certain XY  location but that vi was not presented in the default NXT functions pallet ,nor was it clear to me that such vi exists. I have found it in the dual mode vi library C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\NXT\Dual Mode Library and attached it also to the tools.
Now I did not need to use old remote vi s so it is OK now I attach the program I wrote and if you find this example usefull for showing others, you can use it.
Regards
Moshe Epshtain
(3,150 Views)
