Writing data to file in a timed loop
I am editing a previously made block diagram, and I'm having trouble writing my data to a file.
I want to have the mean histogram value recorded every 5 minutes into a data file
Do I need to worry about error?
Here is the vi attached as well.
(3,317 Views)
Not much info to go on here.
What error are you getting?
(3,299 Views)
Indeed that was vague.  I'm completely new at labview, do I need to route error wires through my file saving operations?  If I set it up for a save file prompt, will the time loop save to that same file on each of its iterations?
(3,290 Views)
It is always a good idea to wire up the error wires.
For a file save, it all depends on how you program it.  If you have a prompt that you ask for a filename before starting your loop, it will always write to the same file.  If you put the prompt inside the loop, it is going to ask you for a filename each and every time which will be a pain to the user.  If you wire it up as a file path control inside the loop, it will give the user the option to change the file path during execution.
If you want to have the ability to prompt for a new filename anytime during execution, but perhaps only when the user hits a button on the front panel such as New File?, you can put the dialog prompt function inside a case structure.  Then by putting the filepath wire into a shift register, that file path will be available for later iterations.
Since you are completely new to LabVIEW, you may not have seen these.  I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,274 Views)
