Writing data to a file
Hi
My application writing data to a file using producer consumer loop architechture. Producer loop is acquiring data form DAQmx, process data and output the result to a output channel of daqmx one sample at a time (my application is a control system). consumer loop writes data to a file for later analysis using another software. I need to write format, title, nchannel and list of channels to the file first (thease are some lines) . I think that is how other software reads the data or recoganize how many channels to do the analysis. i want to write these lines to the file first and then data. i was able to write data. Is there anyway to write these lines before i write data to the file.
(2,889 Views)
Sure.  Have a special case in your consumer loop.  Either on iteration zero of the loop, or when a special command is sent through the queue, that the header data is written.  Or you could have the header data written to the file before the consumer loop starts.
(2,879 Views)
Thanks for the reply. Could you explain how to write the header lines before the consumer loop starts? thanks
(2,855 Views)
Like this.
Message Edited by Ravens Fan on 09-17-2008 09:45 AM
(2,851 Views)
