Writing continuous data to excel in different columns?
I am aquiring 4 different types of data continuously and I need to put each in a seperate column in excel. What should I do?
(Building these data in 2D array is not an efficient way, is there any other way)
Message 1 of 12
(4,135 Views)
Writing to a real Excel file using ActiveX is a resource hog.
Message 2 of 12
(4,131 Views)
I am not experienced with ActiveX.
Could I have more detailed explanation.
Message 3 of 12
(4,128 Views)
ActiveX is technology from Microsoft and it provides a means for LabVIEW (or any other program) to access a program that has implemented it. If you truly need to update an actual Excel file, then ActiveX is what you need to use. The easiest way is to purchase the Report Generation Toolkit.
Your question is very ambiguous and needs more details. If you have rows and columns to insert, by definition, that is a 2D array. What do you find so inefficient?
Message 4 of 12
(4,121 Views)
I had the same question before and I was directed to this webpage
http://zone.ni.com/devzone/cda/epd/p/id/1803
I think it's very useful
Message 5 of 12
(4,116 Views)
I am telling you the data are continuously aquired
whihc means the 2D array that will be created will be very huge since my data are aquired in milliseconds
Message 6 of 12
(4,112 Views)
Message 7 of 12
(4,112 Views)
You tell us that you want to write to Excel and we tell you how to do it.
So what is the problem?
Message 8 of 12
(4,105 Views)
why are you talking to me with this tune?
the comment I had was an answer to question
Message 9 of 12
(4,099 Views)
You are not making any sense. I don't understand what you are asking. If you have a large amount of data, then decimate it or don't save it to Excel.
Message 10 of 12
(4,089 Views)
