Writing and Reading Fields in an Executable
Hi there,
I would like to run a small (freeware) program within labview (this program calculates density given pressure and temperature of steam). Using Windows this is really simple; I run the program, click on the temperature field, enter the value, click on the pressure field, enter the value, and press OK. The density is then displayed in another field, I read that then close the program.
What I want to do is make this whole process automatic using Labview (I want to send two numbers to a subvi and then I want it to output the resulting number) How do I do this?
John A.
(Labview 6.1)
(2,602 Views)
Hello John,
From what your are saying I expect that you cannot communicate with this freeware program (Or do you have documentation of a DLL or ??)
Is it not possible to communicate directly to what ever device you use or does the program only performs the calculation?
(2,576 Views)
Hi John,
I think you should find documentation about your program starting: it is maybe possible that you run your program with parameter like:
c:\> name_of_the_program [option1] [option2]
where option 1 and 2 is temperature and pression. The program may return the result of your operation.
But I think that a freeware does not do this...
Sincerely,
BD.
~ La programmeuse compile le C. ~
http://www.pmeonline.fr.st
http://www.nihon-fr.com
http://www.cinemasie.com
http://ippai.free.fr
(2,568 Views)
