Writing Data from Four Channel Osilloscope
Hello Everyone,
I have a DSOX3014A Oscilloscope. I write and read a mesaurement one channel from osilloscope from attacment VI with LAN cable. How can ı write and see four channel measurement from scope? What should ı do ?
(3,097 Views)
You can use the Fetch function to get the other channels after reading channel 1. You would also need to have first enabled and configured the other channels.
(3,088 Views)
Execuse me sir. I understand first part but ı don't understand secand part. What is the having first enabled and configured the other channels means ?
Thank you for your time and attentions.
(3,082 Views)
It means exactly what I said. Each channel should be enabled to read the signal and you should configure the channel for its vertical settings. Haven't you ever used a scope?
(3,078 Views)
Thank you.
(3,072 Views)
