Writing 2D double precision data to binary file broke upgrading from 8.2.1 to 8.5?
I have a VI which continuously aquires and writes a 2D array of double precision data to a binary file using the Write to Binary File function.
It works fine in LabVIEW 8.2.1, but in LabVIEW 8.5 it seems to write all zeros to the file even though a probe on the data input to the Write to Binary File function confirms that the data is indeed non-zero.
Is anyone aware of a change in the way the Write to Binary File function works in going from 8.2.1 to 8.5? I can't seem to find anything about it.
I will try to construct and post a simple example of the problem in 8.5 a little bit later - we are running 8.2.1 right now to get some data.
Thanks for any help,
Ron Norton
Message 1 of 26
(8,501 Views)
Here is a simple example which illustrates the issue.
In LabVIEW 8.2.1 it saves the sine waves correctly as 4 columns of double precision reals. In LabVIEW 8.5 it stores the right number of elements but they're all zero.
A strange thing is that if I remove the transpose operator, the non-zero data is stored correctly as 4 rows of data (although that's not the way I want it in the file for later processing with other software).
Any insights or suggestions would be greatly appreciated. Thanks,
Ron
Message 2 of 26
(8,477 Views)
I am able to reproduce your problem in 8.2.1 and 8.5.  It is very perplexing.
Message 3 of 26
(8,470 Views)
There is an issue in the transpose array.  If I write my own transpose function, the VI works.  In your VI, if I do the following, it will work.
There is some memory issue with the output of the transpose array where the data is corrupted.
Message Edited by Matthew Kelton on 09-28-2007 06:17 PM
Message 4 of 26
(8,464 Views)
Even better - If I create a subVI which is nothing but a wrapper around their transpose (click the transpose icon in your VI and choose Edit->Create subVI), it works.
Message Edited by Matthew Kelton on 09-28-2007 06:29 PM
Message 5 of 26
(8,464 Views)
Very curious problem.
Yes, selecting the transpose, followed by "create subVI" fixes the problem. 😮
If you place two transpose in a row, the problem disappears, but reappears with three transpose operations.
I have reported it in the bug thread:
Message 6 of 26
(8,455 Views)
OK, it seems a memory optimization problem. Fortunately, we have the new "always copy" function. Placing it before the file write fixes the problem!
I always wondered if I'm ever going to use that function anywhere. 🙂
Message Edited by altenbach on 09-28-2007 05:42 PM
Message 7 of 26
(8,450 Views)
Always copy??
It is new..  Can you elaborate on this one (no longer have access to 8.5 😞 )
Message 8 of 26
(8,420 Views)
Yes, that's new for 8.5, complementing the "in place element structure" and others. They are nicely hidden in the "application control...memory control" palette.
I am still struggling to think of a scenario where "always copy" would provide benefits. Typically, the compiler decisions are pretty good. 😉
Message Edited by altenbach on 09-29-2007 09:45 AM
Message 9 of 26
(8,411 Views)
Seems NI introduced some bugs in 8.5...
Just recently I reported a similar bug in LV 8.5 to NI. If you write an array of SGL/DBL to disk using "Write to Binary File" in big-endian format it works as expected. But if you use an index array function (e.g. to extract a row/column) of a 2D-array and wire it's output to "Write to Binary File" it will always save in little-endian format. To test, you can just use build array and index array in a row.
A workaround is to use flatten to string first and write the string to the binary file.
Daniel
Message 10 of 26
(8,405 Views)
