Writing 2-D array to spreadsheet file changes value of time column when saved
I have a program that creates a new row in a table each time the loop performs.  Each time the loop performs and a row is added to the table, the program uses the "write to spreadsheet file.vi" to save this new table over the previous table.  The array is also visible on the front panel of the vi.  The program works in such a way that you can stop adding data to the array, start adding data to a new array, then come back to the original by using the "read from spreadsheet file.vi".  My problem comes after opening the spreadsheet file.  The first column of the array, which corresponds to the time when the data in that row was taken, has different values than those that were seen when the array was originally displayed on the front panel.  In fact, all of the rows that were created the last time the program was run with that array have the same value in the time column, while all of the other columns keep their correct values.  Here is an example of what is happening...
When I start the program, and run it for 5 iterations, I get a table like this displayed on the front panel:
3241713920
85.88012
93.88012
1.735015...
3241713930
85.97603
93.97603
1.747003...
3241713940
84.58855
92.58855
1.573568...
3241713950
84.48096
92.48096
1.560119...
3241713960
84.93667
92.93667
1.617084...
This array is saved to the spreadsheet file with each added row.  If I initialize and build another array, then come back to this first array using "read from spreadsheet file.vi," I will receive the following table:
3241713920
85.88012
93.88012
1.735015...
3241713920
85.97603
93.97603
1.747003...
3241713920
84.58855
92.58855
1.573568...
3241713920
84.48096
92.48096
1.560119...
3241713920
84.93667
92.93667
1.617084...
If anyone could tell me why this is happening and/or how to fix it, that would be greatly appreciated.  One option I have contemplated is just having each individual row appended to the file instead of resaving the entire array with each iteration.  However, I would prefer to do it the way I am currently doing it, so I can pass the array through each time and perform different tasks on it, such as averaging the values in columns over different time periods.  Thank you in advance to anyone who can help.
(3,022 Views)
Can you post your code?  This should not be a problem because it is only writting to file what you give it.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,005 Views)
DWDerr wrote:
If anyone could tell me why this is happening and/or how to fix it, that would be greatly appreciated.  ...
This KnowledgeBase article may help.  I think things changed in LV8.20, but I could be wrong.
Fading out. " ... J. Arthur Rank on gong."
(2,995 Views)
Donald, that link was perfect.. what an easy fix to the problem.  Thank you very much.
(2,985 Views)
