Write to textfile function
I'm having an issue with 'write to text file' function the code runs but the text file doesn't appear neither on MIRIO file system nor on flash drive nor on the host computer
(1,877 Views)
Post some code showing what you have done. Actual VI's rather than pictures please.
Have you got any errors coming up?
(1,874 Views)
It really is impossible to tell you what you've done wrong without seeing code.
(1,863 Views)
Hi forr,
Then you should get an error with those file functions. Do you?
Which filepath do you use? Is the filepath valid (keeping the myRIO in mind!)?
Hint: All those *RIO devices act as a computer of their own, with their own filesystem and their own valid paths. By default a RIO system will NOT save any data to your computers harddrive…
(1,855 Views)
