Write to spreadsheet file common path dialog
Hi guys,
I am facing a road block here.
I am currently using Create File (unwired file path) so that the user can input the file name "test.txt" to create the txt file. No problem here.
However, I want this newly created text file to be my file path to my Write to Spreadsheet File.
Please see attached photo.
Help ! Kudos and thanks !
Message 1 of 24
(5,246 Views)
didnt work
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 2 of 24
(5,237 Views)
Hi poker,
two ways:
Either close the file to get the path or use the file dialog express VI instead...
@Koen:
When the path is provided as "a:" (as is in the given example) then WriteSpreadsheetFile will give an error or does not provide the functionality as requested...
General hint:
Using WriteSpreadsheetFile is a quick way to write CSV files, but has the disadvantage of not providing error I/O connections. And you can't prevent error dialogs generated inside this function... It's (most often) quite easy to use simple file functions in conjunction with ArrayToSpreadsheetString!
Message 3 of 24
(5,236 Views)
Accepted by topic author pokerprof
Why not use Build path? and then send it to Write to spreadsheet file.
uday
Message 4 of 24
(5,233 Views)
Hi Uday,
did you test your suggestion? OpenFile outputs a file reference, not a path...
Message 5 of 24
(5,225 Views)
I mean't use the new file name as string to the build path and the base path as folder path.
Can't we do that way?
uday
Message 6 of 24
(5,209 Views)
Thank you for the input guys.
I have solved it using Build Path.
This is how I did it:
Prompt user input. Output string to the Build Path. The appended path string goes to the file path of Create File. I also create a local variable of the appended path string and it goes to Write to Spreadsheet File.
There you go. Thank you and kudos !
Message 7 of 24
(5,201 Views)
Hi pokerprof,
Most welcome it helped.
uday
Message 8 of 24
(5,192 Views)
Hi poker,
Why do you need a local variable for that purpose?
Message 9 of 24
(5,189 Views)
Cause the write to spreadsheet is inside a while loop and many other case structures. So I guess it is easier to just have a local variable to do the job.
Message 10 of 24
(5,173 Views)
