Write to measurement file, adding column name in text file.
I do everything correctly, better send me a .vi that works and if it doesn't work on my computer then problem is solved.
Message 21 of 29
(2,165 Views)
PLEASE HELP !!!
Message 22 of 29
(2,153 Views)
Hi mrcn,
you got help - a lot of.
You really should follow our advices. Taking the free beginner courses isn't a bad idea, too…
Message 23 of 29
(2,136 Views)
Problem solved!  It is not working on your PC.
If there is a language barrier that is making it difficult for you, post in your native language.
"Should be" isn't "Is" -Jay
Message 24 of 29
(2,123 Views)
Thank you all for the replies. It finally works. I have another question. How to wire it so when I push the button then it saves data.
The problem is that is saves only one value and within every next iteration the value is overwritten by the new value.
Message 25 of 29
(2,101 Views)
You've programmed it to create a new file with each iteration. Why don't you move the header creation outside of all the loops so that it only runs once?
Please take the free tutorials soon.
Message 26 of 29
(2,093 Views)
That's how it ends when you do multiple things like learning and looking after your children.
Thank you for quick reply so I can go to sleep.
Message 27 of 29
(2,088 Views)
You've got children and are able to sleep? Mine are full grown and they still keep me awake at times.
Message 28 of 29
(2,084 Views)
@JÞB wrote:
That's because Tim forgot to change the display fomt of his format specifier string.  \\ sends a literal \ they shoub be single \s and \code display so \r and \t a4e return and newlineSmiley LOL
No I didn't.  I even have the string display style turned on so that you could see that my constants are in \ Codes mode.  I had to do that in order to get the tab inside the timestamp formatting.
Message 29 of 29
(2,057 Views)
