Write to Measurement file time column
Hi everyone
I've currently created a VI that should measure and store DAQ-data continuously in a lvm-file. The time column starts at 0 which is good but after 2 seconds it jumps to whatever (like 18, 20, 32,...) and I have no idea why.
Does anyone of you have an explenation?
Check out the VI attached.
Many thanks.
sciu
(3,374 Views)
Hi sciu,
No, the VI will save data only when time has elapsed - but not continuously…
Do you mind to clean up your VI? (wires from left to right, no hidden code/wires, no hidden labels in the block diagram).
It would also help to get rid of ExpressVIs as much as possible.
It would help to revise the DAQAssistent settings: you are reading 4k samples at 2kS/s samplerate making the VI react quite sloppy…
(3,350 Views)
Hi GerdW
I know, the time has to elapse first before data will be stored. Data should be stored "continuously" when the "time to elapse" is set to "0". It works for all iterations - the time column just counts up. Only after the first Iteration / storing of data the time produces a "jump".
What would you recommend for the sampling rate? The idea was (initially) to store data of 2 sec. after each "time has elapsed" event when the "time to elapse" was set to e.g. 12 sec.
I can follow your advises and rearrange the VI tomorrow.
Thanx
sciu
(3,346 Views)
Hi GerdW
I'm sorry for my late reply. Due to some administrative issues I focused on rewriting the code for the program. Thus the Problem is solved - I removed all express-VIs and also the timing parts of the VI since they weren't necessary anymore.
But thanx a lot for your advises.
Best
sciu
(3,324 Views)
