Write the elements to array
A lot of thanks for this explanation. Some things what do u write here i have known, but it's "%[^=]=%f " was realy surprise for me. I try to repeat  you program, and now I think that the "scan from string function" it's very helpful in my issue. Thank you again, but I have some problem with the case of writing numbers in the array, I mean i cant to do cycle that allow me write parameters of temeprature (in your example it was 36) in the 1-D array. Could u explain this moment.
Message 11 of 13
(1,859 Views)
Hi GerdW,
U re right, Now I see, that i'm realy dont think about dataflow, and the values dont keep from the previous iteration. If it isnt hard for u, can u explain how will I have to create the cycle that allow me to keep the data values and write them.
Message 12 of 13
(1,857 Views)
To retain values from previous iterations you need shift register. Learn more here: http://www.ni.com/getting-started/labview-basics/shift-registers
-Also this about feedback : https://zone.ni.com/reference/en-XX/help/371361G-01/lvconcepts/shift_registers_feedback_node/
uday
Message 13 of 13
(1,851 Views)
