Write in an exel worksheet already existing with Labiview 7.0
Hello everybody!!!
I have a very big problem !!!
I have a program which is able to make measure on my GPIB board and write this measure in an excel worksheet.
Now I must be able to make different operation on this measure , create graph.
How can I do directly with Labview !!
In fact i want to open a worksheet with the different operation save in an other excel worsheet and complete it whith my measure
Is it possible ???
(3,499 Views)
Thanck you
I have done one program but it do not function and I don't know why
i know that all is not link but It would be great !!!!
(3,470 Views)
Simply saying that something does not function is not an proper question. Please be specific as to what is not working. Provide error messages or numbers if applicable. Also, your posted VI does not include many subVIs. If you want to include everything, create an llb by going to Save with Options and selecting Development Distribution. Also, before you repost, clean up your diagram. Your wiring technique is very poor. It's next to impossible to determine what goes where because you have wires going in every direction and hidden underneath other objects. Read the style guide that ships with LabVIEW. It's in Help>Search the LabVIEW Bookshelf. Your case statement also doesn't make much sense. No matter what the state of the Boolean "Bouton OK", the case statement will execute. If that is the intended behavior, eliminate the button and the case statement.
(3,464 Views)
Bon je l'ai un peu modifier soit il me génère une erreur inconnu au niveau de l'éciture dans exel la partie error out
Sinon il tourne normalment mais n'écris rien ???
(3,445 Views)
Hello
Did you read what Dennis wrote?
You must, at least, put the sub-vi, or else we can't test your vi.
(3,444 Views)
Voici le résultat de votre traduction :
I am sorry I thought that it was good!!!! I have remakes a test as said to DENNIS you me repetition if his master key if not I am sorry!!!
(3,434 Views)
