Write a progarm to test two parts at the same time
Hi:
I need to write a program in LabView that is capable of testing two parts at the same time.
Explanation:
I star the test on a unit, once all the electrical test is done move that unit to the pressure test without loosing the current test information and continue the test of the unit thewn generate a serial number only if it passes all the test. Then while the previous unit is going thru the pressure test star testing another unit for the elecrical test and so on.
I am using LabView 2012
(2,663 Views)
What is your question? You can use test stand to do all of that.
(2,659 Views)
And your question is ?
Try to look at NI TestStand, it is a product for this kind for test stations.
(2,657 Views)
@Toro wrote:
[...] generate a serial number only if it passes all the test. [...]
Grrr. Smiley Mad
Jim
(2,632 Views)
From what you have described, I agree with what has been answered above. TestStand is specifically designed for. If you would like to provide more information about your application we could give you a more detailed response. For more information about TestStand follow this link
www.ni.com/teststand
Ryan
Ryan
(2,595 Views)
