Write a XML file
I want to write a XML file to save many informations ( position , size... of my window for example ) and i'dont know how i can do it ,
i used this method " https://www.ni.com/docs/en-US/bundle/labview/page/parsing-xml-files-in-labview.html " but it not work .
Are you have a other method to do this ?
thank youu for your help .
(4,246 Views)
Accepted by topic author imadouino
Can you show the code which you have developed? and what is the issue you are facing?
Did you try using the Write to XML and Read from XML APIs available in LV?
(4,243 Views)
At first it is just a test.
(4,224 Views)
