Write To Spreadsheet File issue
Hi Friends,
I am facing a new issue in on of my VI.
Please see the attached snapshot of the same.
I'm using this Wrtie to Spreadsheet file.vi in one of my VI's.
As a simple VI its working fine.
But when i am running from applicaiton thru some VI and using as a SubVI
Its giving this issue.
Can some body explain what this error exactly means?
THat would be very appreciable.
Cheers,
Suneel.V
Message 1 of 18
(4,809 Views)
I believe the problem is with the File Path. Try putting a 'probe' at the file path input of the function and see if the path is correct and all the folders in the path given are already existing.
Message Edited by Deepu on 07-11-2008 02:38 PM
Message 2 of 18
(4,801 Views)
The error msg says it all doesnt it? "New I/O attempted with old I/O in progress"
U have opened a file and on top of it u r trying to write something.Post ur block diagram we could suggest changes.
Message 3 of 18
(4,793 Views)
Are you trying to write to a same file, same time more than once ? Or are you trying to write to a file opened and locked by MS Excel ?
As muks suggetsed, post your code rather than front panel screen shot so that it would help us better understand ur code.
Message Edited by Deepu on 07-11-2008 04:53 PM
Message 4 of 18
(4,775 Views)
Hi muks,
this "New I/O attempted with old I/O in progress" is a GPIB-related error message. As Suneel is dealing with file access (WriteToSpreadsheet!) the other description "duplicate path" is the interesting one here...
As I never had this error message before I also would suggest attaching your vi (or a stripped down version) here!
Message 5 of 18
(4,760 Views)
Probably the solution is here
It goes like this:
"The New File function cannot overwrite an existing file unless overwrite is set to TRUE and the existing file is not set to Read Only. If you try to overwrite a file without the correct permission, this function does not create or open a file, and the function returns error 10.
To avoid this error, wire a boolean constant of TRUE to the overwrite input of New File."
Hope it helps !
Message 6 of 18
(4,755 Views)
Hi Deepu/muks
Before adding the VI one interesting thing i found from my VI
With the Excel_Input_Automation.xls i am facing this issue.
If the content of the same excel sheet i copied one more VI and try to run the same...
the issue is not observed,.....
So is there anything to do with the excel sheet.
I will add my VI's soon.
CHeeers,
SUneel
Message 7 of 18
(4,748 Views)
Gerd,
          Just name the xl to readonly and try writing data into it.U will get the same error. Right?
Message 8 of 18
(4,737 Views)
I dont get it.
Message 9 of 18
(4,737 Views)
Hey sorry folks,
I've given a wrong info in my above posts.
That issue is also seen even i copied the content to other excel sheet.
But i couldnt reproduce it everytime.
Thats what the issue with...
Today night (i.e 6:00 P.M) IST i would be sitting and debugging that issue..
Please assist me from then on.
Right now hardware is not available.
-Suneel
Message 10 of 18
(4,685 Views)
