Write Multiple Data into Excel
Hi everyone Smiley Happy
I am currently building a project to monitor room temperature using LabVIEW v.6i. I am try to get the data (date, time and temperature) into an excel file. The problem is now i want the data to be seperated into different column. So far the data is filled up in one column per row, as per picture below. I am attaching my VI as well.
What i need to add to make it date in one column, time in one column, and the temp in one colum, all in one row before the new data in another row.
Thanks in advance.
excelvi
Message 1 of 11
(8,169 Views)
That's actually not a LabVIEW issue, but an Excel issue.
You need to get Excel to import the text file in a way that breaks it up into different columns by recoginizing the tab character as a delimiter.
Message 2 of 11
(8,163 Views)
Change the file extension to .txt
Message 3 of 11
(8,156 Views)
Accepted by topic author HeReL
Change your tabs for commas and save your file with the .csv extension. It should open like you want in Excel (you will have to convert the double value to a string).
Ben64
Message 4 of 11
(8,148 Views)
Thanks ben64
I did changed it to comma and it works =). Now what if I would like to insert header into each column such as DATE, TIME and TEMP on top of the colums?
Message 5 of 11
(8,140 Views)
Write that before the loop starts!
Message 6 of 11
(8,135 Views)
Where..?
At the New File vi or the Write File vi ?
Message 7 of 11
(8,132 Views)
After the new file, before the wires go into the while loop.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 8 of 11
(8,130 Views)
Thanks. Will go look into that toturial 😃
Message 9 of 11
(8,104 Views)
As Orioles Fan said, add a write file vi after the New File vi (before the while loop) and write to it this input string:
Ben64
Message 10 of 11
(8,066 Views)
