Would anyone know how to program the Labview code for the following: Recording an analog input signal for 100msec and then repeating this 100 times in order to finally have an averaged signal (waveform)?
I have added a vi, but it doesn't quite work. Would be very grateful if someone could help, thanks!
(3,097 Views)
The attached VI collects 100 ms of data and does a rolling average. Since your sub-VI were not included I created this from scratch. There are comments in the code. I hope this is what you need.
Dirk
(3,097 Views)
Hi Dirk.
Thank you very much for the vi. Unfortunately I can't open it because it runs with LV 7.1. Would it be possible for you to save it for LV 7.0. Thanks for your help.
Kind Regards,
Damien
(3,098 Views)
