Worform Graph:Drag from the tree control then display in the waveform graph
I want to achieve the following function:
Drag channel 1 and channel 2 from the tree control in the left, then in the right the waveform graph will display the two channels.
Does anyone have any suggestions?
Thanks!
Henry
(3,119 Views)
Hi henry,
I would use a listbox instead of the tree:
- you can enable multiple selection mode
- you can easily react on value change events
- the user doesn't need to drag the items: all that is needed is to select them!
- you can easily read the selected items and so put the plots in your graph…
(3,102 Views)
Hi GerdW,
Thanks!
I will give further explanation to my question:
-Drag "Channel 1" to graph 1 and  "Channel 2" to graph 2;
or
-Drag "Mean in Channel 1" and "Mean in Channel 2" to graph 1, and drag "Max in Channel 1" and "Max in Channel 2" to graph 2.
Henry
(3,094 Views)
Accepted by topic author henry_2020
     Check the attached VI.
(3,089 Views)
Hi Jay,
This is the answer I want,Thank you!
Henry
(3,077 Views)
