Word report generation problem
I have a problem with my report generation toolkit. I have programmed a test program (main_program), where i can load a data and print it to a word document.
First i have to load the data(data.txt) and then i have to push the print button.
The header of my is ok, but when the Subvi (write2) tried to generate the graph in the Document always an error occured!
I got an error message but i don*t found the reason why the program stops!?
Error Message:
Fehler -2146827284 ist bei Exception occured in Microsoft Graph, Die Interior-Eigenschaft des Series-Objektes kann nicht zugeordnet werden.. Help Path is C:\Programme\Microsoft Office\OFFICE11\1031\graph10.chm and context 0 in Word_Set_Chart_Colors.vi->Word Set Graph Colors.vi->write2.vi->Report.vi->Main_program.vi aufgetreten
Could sombebody help me, please???
Peter
Labview 7.1 on Windows 2000
(3,008 Views)
Another question....
I want to make a axis label for the y-axis. I can do this with the "word set graph font.vi"!
But when i make this, the label is horizontally. Where can i change this label to vertical???
see the attachement....
PETER
(2,992 Views)
I have solved the problem with the pin orientation!
Peter
(2,978 Views)
