Word_print.vi 1015 error when running exe
I created a vi that generates report in word and prints to default printer. The vi works fine in three different computers with office 2000, 2003 & 2007. But when I create an exe, there is an error: 1015 Word_Print.vi in Print Report.vi. The error is only in system running office 2000. The application was built using LV 8.2 & office 2007. The exe is created with dynamic word vis in support files. I also tried addind Word_print.vi in the support files.
Could you please let me know what I else I could do?
U
(3,226 Views)
Hi uka001,
Are you able to print from the default printer on the system generating the error?  Error 1015 means: "Printer is not responding. Check printer configuration."
(3,211 Views)
Thank You.
THe printer is configured right as I can print with the development vi. When I build the vi as an executable, it fails to print. The development computer has office 2003, and the test computer has office 2000. When I install office 2003 in the test computer. The exe works and prints. I just upgraded all my test computers with office 2003.
Is there another solution?
(3,205 Views)
Ah, understood.  Which version of the Report Generation Toolkit do you have installed?  All versions, except maybe 1.1, have a folder on the package CD called Compatibility.  Within this folder are directories such as Office 97, Office 2000, [Office XP], [Office 2003], and [Office 2007] (toolkit version determines if you have the items in brackets).  If you dig into these directories, you'll eventually discover the file _wordsub.llb.  This library contains the appropriate _Word Dynamic VIs.vi that you'll want to include in the "support files" section of the application builder.  Refer to the Office.txt document found within C:\Program Files\National Instruments\LabVIEW 8.X\vi.lib\addons\_office directory to confirm what I said.  Thus, to create an executable that will print from your Office 2000 test machine, include the _Word Dynamic VIs.vi from the Compatibility\Office 2000\vi.lib\addons\_office\_wordsub.llb library on your Report Generation Toolkit CD.
(3,172 Views)
