Wireless Syystem (WLS 9163)
Hello Forum.
I am using the following equipment from National Instruments:
NI WLS 9163
NI 9219
I set 9163 as the NI WLS wireless system through an ad hoc network.
I and acquiring the values ​​of resistance (voltage with custom Excitation) of load cells wired in full bridge.
Everything works!
However, the acquisition rates are very low!
I can not get acquisitions with more than 2 Hz (high resolution)!
Will can help me on the following issues:
This is because the equipment I am using?
How can I change that with this equipment?
There is another wireless system from NI, with better results for this application?
I appreciate the help! Smiley Happy
(Not sure if this is the most suitable place, also posted in Wireless Sensor Networks)
(2,874 Views)
What kind of problem do you have if you choose to get data at a higher rate than 2Hz ?
Which version of DAQmx do you use?
Could you post a screenshot of your configuration in MAX and tell us which IDE do you use? Is it LabVIEW?
Do you have a VI to post?
Jérémy C.
NI France
(2,849 Views)
Dear Jeremy C.,
Thank you for your answer. I saw that this was not the right place for this message. You can visit:
http://forums.ni.com/t5/Multifunction-DAQ/Wireless-System-WLS-9163/mp/2101306 # M72264
Have added some prints.
Thank you!
(2,839 Views)
Hello again,
Allow me to correct your link : Wireless System (WLS 9163)
Jérémy C.
NI France
(2,836 Views)
