Wire error stating FIFO Data type is 1D array
I have a Host to FPGA DMA FIFO with data type defined as U32. On the Host, when I try to wire a U32 constant to the Data field in the Invoke Method block for the FIFO write, I get a wiring error stating that the sink type is a U32 1D array. Why is this happening when a FIFO can't use arrays as a data type?  Attached a screenshot of this error.
(2,548 Views)
Because the FPGA is FAST.  Therefore the host will need to write multiple data points at a time.  The simple solution for you is to just add in a Build Array sized to 1 element to turn your single numeric into an array.
(2,525 Views)
