Wire Class Conflict
Hey, so I recently tried to add some new features to a LabVIEW program that we have been using for about a year. In doing so, I created an error that says "Wire Class Conflict". I have the rest of the program working how I want but this one error appears as I bundle references on initialization. How can I resolve this error? Any insight would be greatly appreciated as the concept of class hierarchy is a little foreign to me.
Message 1 of 13
(2,957 Views)
Well, there are a ton of VIs in here and no classes.  Where are you seeing this error?
Message 2 of 13
(2,953 Views)
So, the error is coming as I bundle the "Test Modules" cluster into my refnum cluster right in the main vi.
Message 3 of 13
(2,945 Views)
Ok, you have a type conflict due to your cluster reference.  Make the cluster a type def, update the reference to use that type def, and then update all cluster constants you used to also use that type def.
Message 4 of 13
(2,942 Views)
That is where I get a little confused. So, the test modules cluster is a type def that is already updated. The refnum cluster itself is also a type def as shown attached. If I go into the type def, I can see that there is a cluster reference for "Test Modules". I'm not entirely sure how to update this to match the new test modules type def as it is a strict type def. I recognize that this might be a fairly simple thing to fix. I just haven't really dealt too much with things like this in the past. Any insight on how to make this change would be greatly appreciated.
Message 5 of 13
(2,927 Views)
Your "Test Modules" cluster (at least on the front panel) was not type defined.  And neither is the data type in the Test Modules reference in the giant cluster you are using.
Message 6 of 13
(2,918 Views)
You are absolutely right. There is another type def that is called "Test Modules" that is used throughout the program. I just assumed that the front panel also used that type def but apparently not.
One last question, how do I place a type def'd refnum into that giant cluster? I'm sure that's probably a really dumb question. I just haven't had a very formal LabVIEW education.
Message 7 of 13
(2,892 Views)
Find the refnum in your giant cluster.  Right-click on it and make the control visible.  Now drag your new cluster into the reference.  You can then right-click on the reference again to make the control not visible again.
Message 8 of 13
(2,879 Views)
FYI, a common mistake I make when I forget- if you make a typedef and try to drag it to a front panel or block diagram, you can't grab the cluster in the typedef. You need to grab the icon. If you just drag the cluster, it looks like it works but you don't actually get the link to the typedef.
Message 9 of 13
(2,866 Views)
I almost always drag from the project, so I don't have that issue.
Message 10 of 13
(2,862 Views)
