Windows media player in browser asking to replace html file every time
Hi Alll,
I have a case in which I am running a WMP in a Browser using ActiveX container , the problem I am facing is on every run its asking me to replace the existing html file in the folder , Is there a way to get rid of that, I dnt want to click replace every time. Is there a easy way of doing this.
Please let me know.
Ankit
(3,044 Views)
Hi AnkitG,
What is the VI inside your sequence structure? Could you post a code snippet instead of a .jpg?
KyleP
(3,022 Views)
Here is the vi in sequence structure.
@_Perky wrote:
Hi AnkitG,
(3,015 Views)
The dialog is being caused by the Write Characters to File VI that you are using. If the file already exists, it will ask you if you want to replace it. Instead of using those VIs, just use the Read From Text File and Write to Text File functions that are in the File I/O palette.
Your code has another issue: your use of the Current VI Path constant. See Why Does My Executable Not Work When Using the Current VI's Path Constant?
(3,011 Views)
Accepted by topic author AnkitG
Thanks, It was very helpfull
(3,008 Views)
